Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
Thread: Help with base tune?
    Jan 2018
    Default Help with base tune?
    Hey guys,
    I'm very new to EFI live tuning but i've been doing tons of research trying to get the base tune for the new setup on my truck. Here are the details:
    05 4.8 silverado
    Deka 80lb injectors
    FPR regulator set at 58psi with boost reference.
    Walbro 450
    3 bar map in stock location
    S475 t4 turbo
    I'm trying to get the basic things done on the COS so it will atleast start and drive so i can do some tuning. I have inputted some of the injector data but i'm confused on a few things. On my xcel spreadsheet it shows "offset" but i have no idea where to paste in this table on EFI live. I am ASSuming it's under table B3701? Also confused where "fuel to wall transient" goes in EFI live. I will attach the spreadsheet and my tune if anyone has time to look them over. Also if anything is way out of wack please tell me. Thanks guys!
    -Ryan
    Denver,CO
    Hi Ryan,
    Quote Originally Posted by Burnett03 View Post
    Yes, that's correct.
    This would be table B3406 "Impact Factor"... but your tune does not have this table (see under Fuel->Dynamics).
    Also do this: set FPR to 58 psi with reference hose temporarily unplugged (i.e. open to atmosphere)
    ( after setting FPR, be sure to reconnect reference hose )
    Last edited by joecar; February 26th, 2018 at 11:43 AM. Reason: fix spelling of Impact
    Jan 2018
    As always, thank you for taking the time to help Joe. I'll do that.
    Jan 2018
    Guys I've finally got the truck ready to actually drive. I've started it and it seems to idle fairly well when cold. Once the truck warms up if I turn it off and try to restart it I have to keep my foot on the gas to keep it running. I'm assuming maybe its because the truck needs to relearn the idle? What is my next step tuning wise? I've followed the tutorial in the custom o/s upgrade and deleted the maf. The truck is on a separate IAT sensor and a 3 bar map sensor now. I've also added an AEM wideband and have it logging through efi live via serial. What is my next move? Do I now following the AUTO VE tutorial? I no longer have a MAF sensor, just the 3 bar map, do I still follow this tutorial? Thank you so much guys!
    Post tune file and log files.
    Jan 2018
    Here is my current tune. I will get a log file of idle this weekend once i weld the muffler on. Thank you.
    What injectors do you have...?
    Did you measure rail pressure (with reference hose removed)...?
    Jan 2018
    Deka 80lb
    Rail pressure is 58psi with vacuum line removed.
    Jan 2018
    Here are two idle logs, plus my tune. i added some airflow to B4307 when hot and it made it idle pretty good hot for a while. Shut it off after 20mins of idle time and i couldn't get it to idle again without babying the throttle with my foot. My second log is when it was a hot restart and didn't want to idle. Thanks
    You may have to do rafig/idle tuning.
    I'm still looking thru your files.
  1. need a 408 base tune
    By 383camaro in forum Gen III V8 Specific
    Last Post: May 1st, 2013, 03:19 PM
  2. help with base tune 6.7L
    By O1Z06 in forum Gen III V8 Specific
    Last Post: August 31st, 2012, 02:04 AM
  3. Good N/A Tune but...Going Supercharged I could use advice on a base tune
    By tatasta in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: April 6th, 2011, 08:16 PM
  4. Need a base tune
    By BRD-PREY in forum Gen III V8 Specific
    Last Post: August 15th, 2009, 02:14 AM
  5. Base Tune?
    By vetteboy2k in forum General (Petrol, Gas, Ethanol)
    Last Post: July 9th, 2005, 12:11 PM
