Page 4 of 4 FirstFirst ... 234
Results 31 to 38 of 38
Thread: Help with base tune?
  1. #31
    Jan 2018
    +1 on what statesman said, be careful to not allow knock.
    First get NA tuned/running right (including idle).
    Not going into boost indicates a physical problem, you will have to fix this first.
    The truck will boost just fine but goes pig rich at around 3psi. I followed the COS tutorial to create a starting point for the boost ve table but it seems way to rich.
  2. #32
    Jan 2018
    Quote Originally Posted by statesman View Post
    Tuning a boosted engine while learning the basics... now there's a recipe for disaster.
    I don't do much tuning on turbo boosted engines. You really need to get the EGT into the happy zone for the turbo to work well, which can be an absolute PITA... but that's something to worry about AFTER you get the basic tune right.
    I might be able to give you a nudge in the right direction. Does your engine have a MAF sensor fitted?... and what mods have been done besides what you've already told us about?
    I didnt realize people were still using egt to tune turbo gas motors. I assumed everyone was using wideband like me.
    Here is what's done:
    4.8
    COS3
    s475 t4 turbo
    fmic
    aem wideband
    dual walbro 450s in tank
    AFPR set at 55psi with vacuum line off
    Deka 80lb injectors
    No maf
    gm iat in upper boost pipe
    3 bar map sensor
    4" exhaust
    Thanks for offering to help.
  3. #33
    Can you post your calc_pids.txt file.
  4. #34
    Aug 2013
    Quote Originally Posted by Burnett03 View Post
    Yeah, you can tune with the wideband and that will get your fueling 'right', so to speak.... but EGT is governed by a combination of fuel and spark. Let's see how long your turbo lasts if you end up running really high EGT and you overheat the turbo.... your wideband will still be reading 'right' while your turbo is exploding.
    Some of us old folk actually understand the importance of EGT on turbo'd engines... which is why I mostly avoid tuning them. It's also why supercharging is so popular now... the worst you can get with a badly tuned supercharged engine is glowing headers.
    I'll try to look over your files in the next day or two.
  5. #35
    Jan 2018
    I hope you didn't take offense to that. It wasn't intended that way. Back when i was big into 4 cylinder turbo cars all we had to tune with was a narrowband o2 and an EGT. I understand the importance of high EGT's i just hadn't seen many people using them anymore. Obviously both my diesel trucks have them and i monitor them like a hawk. Thanks for your time.
  6. #36
    Jan 2018
    I've attached the calc_pids
  7. #37
    Aug 2013
    I've had a look at your files and here's what I've found...
    The rich in boost is because you've set your Boost VE Table {A0009} wrong. People who don't have a boost referenced FPR have that table sloping up because they need to compensate for the reduced injector flow rate in boost... but you do have boost referencing, so your boost ve table needs to be a lot flatter.
    As joecar has pointed out to you previously, your Main VE Table looks wrong. You've dug a massive hole in it trying to combat a rich decel... and the rich decel is still there. Make the following changes...
    {B4003} Minimum Injector Pulse Width... Set all values to 0.25
    {B4004} Default Minimum Pulse Width... Set all values to 0.25
    {B4005}Small Pulse Adjust... Set all values to zero.
    You should have less problems tuning the VE with these settings.
    Your main spark table is flat above 0.8g/s... you're likely to exceed that, so be careful you don't get any knock. Personally, I'd slope the spark table down a bit while tuning and then bring it back up slowly while you're actually tuning the spark.
  8. #38
    Jan 2018
    Ahh that makes perfect sense, thank you.
    Yes it's very rich on decal according to the BEN map.
    I will do this, thank you.
    Got it. Thank you for taking the time to help me.
  1. need a 408 base tune
    By 383camaro in forum Gen III V8 Specific
    Last Post: May 1st, 2013, 04:19 PM
  2. help with base tune 6.7L
    By O1Z06 in forum Gen III V8 Specific
    Last Post: August 31st, 2012, 03:04 AM
  3. Good N/A Tune but...Going Supercharged I could use advice on a base tune
    By tatasta in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: April 6th, 2011, 09:16 PM
  4. Need a base tune
    By BRD-PREY in forum Gen III V8 Specific
    Last Post: August 15th, 2009, 03:14 AM
  5. Base Tune?
    By vetteboy2k in forum General (Petrol, Gas, Ethanol)
    Last Post: July 9th, 2005, 01:11 PM
