Results 1 to 10 of 11
Thread: Calc PID is driving me to drink
    Aug 2015
    Default Calc PID is driving me to drink
    I'm trying to make a calculated PID for idle rpm error. I've tried entering it every way I can think and the darn thing won't appear in my PIDs list. It won't even show up as an invalid PID. Here's what I have so far:
    # Add slot definitions here
    *CLC-00-004
    RPM -200 200 0.0 "{SAE.RPM]-{GM.IDLRPM}"
    CALC.RPM_ERR F110 CLC-00-004 RPM Conditions "Idle err"
    Any ideas?
    Hib Halverson
    just another f'ing "Tuner In Training"
    Hi Hib,
    You have a square-bracket here instead of a curly-brace...
    *CLC-00-004
    ( also make sure you have at least 2 blank lines at the end of the file )
    Aug 2015
    Hi Hib,
    Pretty dumb, huh.
    LOL
    Guess I need a stronger pair of computer glasses...or maybe, being frustrated I started drinking and it went downhill from there.
    (sigh)
    Didn't think of that either.
    Thanks, Joe!
    Hib Halverson
    No worries... stuff happens.
    Aug 2015
    Guess I better go buy another six-pac. Even after I corrected that one character and added boocoo lines to the end of the file, that one calculated PID still won't appear.
    Hib Halverson
    Ah, the other problem is that the units RPM should be rpm (lowercase)
    *CLC-00-004
    See attached.
    Aug 2015
    Still not working.
    More beer!
    Hib Halverson
    Quote Originally Posted by Hib Halverson View Post
    Still not working.
    More beer!
    It's never too early for beer
    Try the attached calc_pids.txt (in post #7)
    on PIDs tab, click on the column heading Parameter to sort on this column;
    then (looking down the Parameter column) find and select the pids SAE.RPM, GM.IDLERPM, CALC.RPM_ERR...
    the pid CALC.RPM_ERR should not have a red X thru it.
    Aug 2015
    No arguement.
    Now it appears in the list, but it's has the non-supported "x" over it. Now what?
    I know..more beer.
    Hib Halverson
  1. calc.pid /sae.generic - pid resoultion question
    By cyipher in forum Gen III V8 Specific
    Last Post: February 6th, 2014, 12:00 PM
  2. Can some help me with a calc pid please.
    By pavetim in forum Diesel
    Last Post: February 4th, 2011, 12:17 PM
  3. calc.pid help
    By mr.prick in forum General
    Last Post: June 1st, 2010, 01:28 AM
  4. e38 dma pid SCALEDCORVE_ doesnt work plus a bad calc pid
    By ringram in forum FlashScan V2 BB Logging
    Last Post: November 30th, 2008, 10:28 AM
  5. hp calc PID
    By pwilson22000 in forum General
    Last Post: July 24th, 2006, 11:58 PM
