Results 1 to 5 of 5
Thread: E92 throttle won't go past 33%
    Feb 2009
    Default E92 throttle won't go past 33%
    You used to be able to bench test the throttle body and pedal on the e40, e38, e67s. Can you do the same with the l86, lt1, lt4, l83 e92 files? I'm not getting any throttle body or pedal codes? No reduced power message? I've tried both the auto and manual tune files, manual made the blade move a lot further with a Auto file it barely moved at all, I assume because the tcm was missing.
    Do you need the high pressure fuel rail sensor or maf hooked up? In order to go past 33% because I'm getting a bunch of codes for those items missing. I tried simulating the high pressure fuel sensor, and got it sitting around idle 13,000 kpa, but still setting hp fuel codes.
    Which throttle pid are you looking at...?
    Feb 2009
    Tps 1 and 2, and sae and commanded all show 33% plus the blade seems like it's at 33%. Looking at the tb. Pedal is showing 99% pressed all the way to the floor
    Try the pid GM.ETCTP
    Aug 2012
    Any updates to this? I just did my first E92 L83 stand-alone conversion and am trying to bench test the throttle and TB. Ecm flashed fine but I get no throttle movement at all with the harness powered up. Even with scan tool hooked up the TPS values don’t change.
    With key on, engine off does a 2014-2016 Silverado throttle body open and close? Or does it only move when engine running and no codes?
  1. p16a1 With e92 is it possible to bench test the throttle body/pedal
    By 04colyZQ8 in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: February 23rd, 2018, 04:44 AM
  2. 2012 LS3 won't rev past 5700 codes P0100& P0400
    By TurboCamaro in forum E37, E38 & E67 PFI ECM's
    Last Post: June 1st, 2017, 02:04 PM
  3. 2014 E92 5.3 sierra throttle response mods
    By efiexpress in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: June 30th, 2015, 04:37 AM
  4. Cleaned throttle body, now E38 5.3 won't idle correctly
    By Stroked250r in forum E37, E38 & E67 PFI ECM's
    Last Post: June 26th, 2015, 06:22 AM
  5. LS2 Transplant won't go past idle.
    By Scoota in forum Gen IV V8 Specific
    Last Post: April 20th, 2007, 05:57 PM
