I've got an ECM that has a custom key applied to it. I've got the custom key, and I can read/write when using the custom key. However, I'd like to switch the ECM to just use the standard EFILive key, so I don't have to mess with the custom key field every time I want to tweak this one.
Is there anything that can be done to remove (or change) the key?
