Results 1 to 3 of 3
Thread: Changing custom key value in "locked" E67 ECM
    Apr 2016
    Default Changing custom key value in "locked" E67 ECM
    I've got an ECM that has a custom key applied to it. I've got the custom key, and I can read/write when using the custom key. However, I'd like to switch the ECM to just use the standard EFILive key, so I don't have to mess with the custom key field every time I want to tweak this one.
    Is there anything that can be done to remove (or change) the key?
    Assuming you have a FlashScan and not an AutoCal, you should be able to use the V7 software to revert the key back to the stock key using the Locking/Unlocking option and by supplying the custom key value that you already have.
    Apr 2016
    I do, thanks!
  1. Replies: 30
    Last Post: May 24th, 2017, 11:08 AM
  2. "controller locked with custom key" DEAD ECM
    By DURAtotheMAX in forum Duramax LLY
    Last Post: May 14th, 2012, 01:25 PM
  3. Replies: 14
    Last Post: June 20th, 2009, 04:48 AM
  4. EFILive "Classic"/"Legacy"/"Historic"?
    By emarkay in forum FlashScan V2
    Last Post: November 2nd, 2008, 02:48 AM
  5. Vat relink??? Says "Locked with custom key"
    Last Post: September 6th, 2005, 03:15 AM
