Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Help with segment swap
    Dec 2005
    Default Help with segment swap
    Can someone look over my tune to see if anything sticks out and verify I completed the segment swap properly?
    I just finished the 4l80 swap and it seems the trans is stuck in limp mode. I have Park, Reverse, and Neutral, but D-3-2-1 all are the same. It seems to be stuck in 3rd gear. Thanks in advance.
    Dec 2005
    I think I may have found the problem. It's actually called a "segment swap" and it's under the "Edit" section on the top tool bar in the program. When you don't know, you just don't know.
    Dec 2005
    But now I can't reflash my pcm because it keeps giving me an error that this is a scan only device and I need to upgrade to a flash tune and scan. It's so damn annoying because I've been using this same flashscan cable since 2005. Maybe that's the problem..or bad USB cable???
    Did you enter your blue-card information here: Help->Register EFILive
    Dec 2005
    Yes sir. I've been using this same equipment since 2005 and now it's acting up on me
    Can post a screenshot of that window...
    Quote Originally Posted by 12sec.5.3 View Post
    Is your device a FlashScan V1 with a Personal License? If so the Personal License was discontinued years ago and replaced with the Commercial License only. Send your FlashScan V1 serial number to me at paul@efilive.com (with a link to this thread) and I'll send you back a free Commercial upgrade.
    Dec 2005
    Thanks guys, I really appreciate it. Someone from the tech dept got me hooked up and I'm back up and running. Now to tune out the bugs...
    Dec 2005
    There was something wrong with the software that was stopping me from flashing my ecm but Andrew was abled to get me back up and going. Big thanks to him.
    I'm not really a guru at this tuning thing like many of you so thanks for all of the help and support. I have a few things I'd like some help with.
    1. What would cause my TCC to lock up then unlock 2-3 seconds later and stay unlocked? I've had this problem for years and never bothered with it because the 4l60 was a ticking time bomb anyways. Now that I have the 4l80 in I'd like to get this solved.
    2. I'm unabled to hold 1st gear(doing burn outs and what not) without it shifting on its own. I'd like control of that again.
    Once I get my exhaust tied back in then I'll be abled to ride around town and fine tune things better...as of now it sounds like loud annoying garbage lol. Straight out the Y-pipe.
    Dec 2005
    Also, I'm getting a code P0443 Evaporative Emission (EVAP) Purge Solenoid. Can I just turn the MIL off and forget about it or does this NEED to be fixed?
  1. Need help with segment swap
    By 12sec.5.3 in forum Gen III V8 Specific
    Last Post: February 19th, 2018, 03:34 PM
  2. 4l80 swap with frost harness without segment swap
    By james workman in forum Conversions / Aftermarket Parts
    Last Post: March 10th, 2017, 04:12 PM
  3. What does a segment swap do?
    By Mean Green Z28 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 6th, 2016, 07:52 AM
  4. How do you do a segment swap?
    By Redline Motorsports in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 8th, 2012, 08:18 AM
  5. Segment swap...Q's???
    Last Post: November 6th, 2007, 07:14 PM
