Is that your current tune file in post #1...?
Also: set D0961,2 to 100% all cells.
I'm looking at the other TCC parameters... you may be interested in playing with some of them, see attached cax file for 12212156, unzip it to folder C:\Program Files (x86)\EFILive\V7.5\Calibrations
go look at tables D1010-38.
Actually this is the current tune file I'm running. I'll def take a look at the things you pointed out, thanks a bunch!!
I can't open that file either. I'm not sure if it's something I'm doing wrong or if it's this laptop. When I download that file and try and open it still says file not supported.
So I was unabled to download the file but I did find another file with the same 12212156 OS with a complete different set of TCC parameters. I'm assuming it's the file you attempted to send me. I copied and pasted them over and will see what that does.
