Results 1 to 4 of 4
Thread: LB7 Scanner
    Lifetime Member Road's Avatar
    Feb 2015
    Default LB7 Scanner
    I can't connect to a LB7 with my V2 for data logging. Can read and write to the truck. Tried removing radio, different cable etc. V8 and 7.5. Hpt data logs it just fine. I see no E54 configs when checking firmware. Firmware is up to date.
    Feb 2015
    Tried 2 different trucks even tried a Autocal. Same thing......
    Dumb question, are all the PIDs validated for the LB7 in the BBX window?
    Feb 2015
    I know they are not in 7.5. Can't remember if they were in 8. I need to command 4th gear and data log so was trying 7.5 mainly.
  1. V8 scanner
    By SW1911 in forum Petrol / Gas
    Last Post: April 29th, 2014, 12:17 PM
  2. 01 LB7 PCM in 04 LB7 truck?
    By KLUG'S SS in forum Duramax LB7
    Last Post: December 26th, 2013, 02:25 AM
  3. Can't even use scanner, please help
    By pavetim in forum FlashScan V2
    Last Post: January 25th, 2012, 10:56 AM
  4. 03 LB7 pcm into 01 LB7
    By red12secz28 in forum Duramax LB7
    Last Post: November 19th, 2007, 10:40 AM
  5. Scanner help
    By wickedred in forum General (Petrol, Gas, Ethanol)
    Last Post: June 22nd, 2007, 11:10 AM
