Results 1 to 10 of 10
Thread: VVE Bump!?
    Oct 2010
    Default VVE Bump!?
    Doing the VVE following the guide. And for the life of me I cant get the curve to be 'smooth'.
    I started aligning to 4 zones,stepping down to currently 2 after about 5 iterations each step.
    Using B8101 as I will be using the MAF once the vve is dialed in.
    2010 Camaro LS3
    Stock heads
    AGP Twin Turbo
    LS9 cam
    LSA injectors
    3bar MAP
    Log_0001.efi
    SS_Tune_0001.ctz
    What am I doing wrong?
    Thanks!
    Which wideband are you using...?
    You wideband does not make sense when Lambda is 1.00:
    are you sure it's working ok...?
    Oct 2010
    It's a Innovate MTX-L, the gauge seems to match the logger (which updates a lot faster)
    My calcpid is below. I think its correct to the way the voltage output is configured.
    *CLC-00-001
    AFR 10.00 17 0.4 "(({EXT.AD1}*0.0952)+0.68)*14.7"
    lambda 0.68 1.156 0.4 "({EXT.AD1}*0.0952)+0.68"
    **EDIT**
    Voltage output
    Quote Originally Posted by opcode View Post
    *CLC-00-001
    Yes, the lambda equation correctly equation matches how your MTX is programmed in the image below.
    **EDIT**
    Voltage output
    Let me work your log thru the procedure...
    Does your B4001 IFR table come from the LSA stock IFR table...?
    Also, do your other injector tables come from the LSA stock tune...?
    I need to look at a stock LSA tune file...
    Oct 2010
    2013 Chevrolet Camaro Coupe Manual LSA 6.2 Litre (12653669).ctz
    Here is the lsa tune I sourced the injector data from.
    ok, thanks.
    I'll look at your tune/log files during the day...
  1. Replies: 1
    Last Post: February 2nd, 2012, 10:58 AM
  2. Need VVE tuning help
    By 2007chevy5.3l in forum Gen IV V8 Specific
    Last Post: August 25th, 2011, 01:39 PM
  3. VVE Help
    By etmotorsports in forum E37, E38 & E67 PFI ECM's
    Last Post: February 4th, 2011, 04:52 PM
  4. Throttle body bump stop
    By maudyZ28 in forum Gen III V8 Specific
    Last Post: April 27th, 2010, 09:34 AM
  5. VVE question
    By Ed@Late Model Speed in forum E37, E38 & E67 PFI ECM's
    Last Post: February 19th, 2009, 10:28 AM
