Results 11 to 20 of 37
Thread: Table Request
    May 2016
    His complaint was specifically that it idled very rich. No matter what tables i defueled, i couldnt log lower fuel delivery. I like the idle to be at 750, as it accentuates the rumble made when vanes are commanded open at idle. It sounds like a truck and less like a hair drier. With that, the fix/bandaid was idle at 900r vs 750r ... I could defuel as needed with torque to fuel tables, just lost the rumble in the process since its 100r over the rpm i have for when the vanes start to close
Name:	Base Qty vs TPS.JPG
    May 2016
    Ahh i remembered another inquiry... In Scan v8, data logging the various injections... We have 2 pilots in the ecm calibration that supposedly run but i can only log when one of them is on/off... Specific PID is IEASTAT under GM Enhanced... Is this a limitation of scan v8?
    It'll just be the PID itself, GM defined its operation not EFILive.
    The table you've shown above I don't think is a base fuel to mm3 table based on TPS for idle, I think it is fuel limiter when torque reduction is active. Obviously I can't see in HPT where you've pulled that from but is it in the Trq reduction group?
    May 2016
    I found it in the Main Injection params... I was attempting to defuel by reducing the torque to fuel tables, and i was not able to reduce fuel using that table. I had reduced to a value that should not have run, but continued to idle with no reductions in fuel per datalogs. I was able to get an improvement by increasing rpm to 900, which coincides with what i should be seeing per that "base qty" table. There is something that i am aware of from my experience, that the main torque to fuel tables are way wrong in the other guys software. That is the specific reason i stopped using it on the e98. It does not line up with data logs. The mm3 values are scaled in a way that the tables only show 50% of the value. Anyways that beyond the point... This particular truck, the operator complained about excessive smell, even while in the cab. He is +5000ft elevation, Baro reports 12.038psi. I was able to raise idle speed to 900rpm and there was a large improvement, but still has a lingering smell
Name:	Base Qty vs TPS.png
    While not fuel related, I still would like to get the multiplier & adder tables for SOI timing.
    May 2016
    That is definitely fuel related, on a diesel
    Sent from my XT1710-02 using Tapatalk
    you are correct, i had my head in "petrol land" as i was looking at some e38 stuff when i wrote this. lol.
  9. #19
    May 2016
    Following up
  10. #20
    in a couple of months i'm going to be adding another turbo to mine for a compound setup, so I would be happy to test/play around with vane control too if we can get them added over time.
  1. T43 Table/s Request
    By hacklerjason in forum E98 2014+ Diesel ECM
    Last Post: February 6th, 2018, 09:42 AM
  2. Surging TCC Lockup - Table request
    By Tre-Cool in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: December 12th, 2017, 10:42 AM
  3. Request for raised mA table
    By 2007 5.9 in forum Cummins 6.7L
    Last Post: September 26th, 2017, 10:00 AM
  4. No A/C torque reduction table in E38 tune? B4358 spark table?
    By Mean Green Z28 in forum E37, E38 & E67 PFI ECM's
    Last Post: June 19th, 2014, 01:30 AM
  5. COS5 nitrous table request
    By johnv in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: August 19th, 2009, 04:04 PM
