Results 1 to 2 of 2
Thread: LBZ injectors in a LMM
    Jan 2015
    Default LBZ injectors in a LMM
    I have searched for the answer and haven't been able to find out for sure but can you tune a LMM to run LBZ injectors. I have a LBZ drivetrain on hand I am wanting to put it in a Cadillac Escalade but I have to run a LMM ECM for communications with the body control module. I will do an EGR and DPF delete which will do away with most of the differences between the two. I know the MAF sensor is different and a few other minor things but I can overcome that pretty easy. The injectors are almost new 30 overs and I was trying to save some money by not having to buy new LMM injectors.
    Lifetime Member LB72004's Avatar
    Dec 2011
    2008 Chevrolet 3500HD DRW LTZ
    285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
    Sold - 2004 LB7 Duramax, EFI Live with DSP5 Tune
    stage 4 SC transmission, 265/70/16 tires
  1. Lbz injectors
    By mccormick28 in forum General
    Last Post: December 2nd, 2016, 11:05 AM
  2. Lbz injector replace with 24lpm injectors
    By dlshandera in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 26th, 2016, 05:59 AM
  3. Using LBZ injectors and pcm on detroit diesel
    By boothybunch in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 3rd, 2014, 03:20 PM
  4. LMM ECM for '06 LBZ?
    By badassmax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 7th, 2011, 09:03 AM
  5. Gm.trq_fact_dma lbz/lmm
    By Biodiesel66 in forum FlashScan V2 BB Logging
    Last Post: October 28th, 2009, 12:34 PM
