Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: E92 GMC missing table
    May 2010
    Its very bad that I have to add 4-5 degrees of timing to high octane table the when I finish tuning the car I have to subtract it again and advice the customer that he will see the maximum performance after 20 mins
    EFILive Tuner
    Nov 2005
    Tables B1954 and B1955 spark humidity modifiers for cam phaser position min and max have now been added for 41 operating systems and will be available in the next release.
    The calz for the OS in this thread is attached. If you require any more ahead of the next software build please let me know.
    Cindy
    May 2010
    Thanks a lot Cindy would you mind to post the calz for OS
    12670948
    12683365
    12677878
    12663390
    EFILive Tuner
    Nov 2005
    Here you go Wesam,
    Cindy
    Jan 2012
    Cindy
    That's great .
    May 2010
    This OS also please
    12672612
    EFILive Tuner
    Nov 2005
    Here you go.
    Cindy
    Jan 2012
    The missing table was added to the new update , thanks .
  9. #19
    Apr 2018
    Quote Originally Posted by Eng.LSX View Post
    I
  1. Is there any table to compensate for bigger TB in E92 ?
    By wesam in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: November 21st, 2016, 09:20 PM
  2. 2011 gmc sierra 5.3 e38 superchargered which VVE table???
    By Pela in forum E37, E38 & E67 PFI ECM's
    Last Post: February 1st, 2016, 05:24 AM
  3. 14 silverado 5.3 E92 Table B8305
    By efilivesteven in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: May 17th, 2015, 11:29 AM
  4. Missing table?
    By JoshH in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 9th, 2009, 03:39 PM
  5. Missing Table B3647 after full reflash
    By MN C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 8th, 2005, 04:09 AM
