Thread: AutoCal Connection Problem PC/Vehicle
    May 2017
    Default AutoCal Connection Problem PC/Vehicle
    I am currently trying to update my AutoCal due to the reason it will no longer after 2years connect to my Truck anymore. The Auto Cal has never ben used with a converter or a laptop so telling me the circuit is fried won
ID:	21916   Click image for larger version.
ID:	21917   Click image for larger version.
ID:	21918   Click image for larger version.
ID:	21919   Click image for larger version.
Name:	EFI USB Veiw.png
Name:	EFI BootBLK Files.png
    Try using EFILive USB Manager and remove the AutoCal drivers, reboot, then use the same program to reinstall the latest USB drivers. If you're using a XHCI port, disable USB3 support or use a USB2 port.
    Are you using a native Windows PC or a Mac with Parallels/VMware?
    May 2017
    Okay for some reason the post did not submit like I typed it.
    May 2017
    Well EFI's forums did not post 7/8ths of the post I created.. im using a very nice fast windows 10 desktop. Iv tried both usb 2 and 3s.
    May 2017
    Okay also just finished uninstalling and re installing usb drivers.... Now HAPI is not running and closes. Tried to run the hapi application and still the problem exists.
    If you posted via Tapatalk, I've seen it cut off forum posts before on other forums.
    Is the AutoCal screen fully on, as in showing readable text when powered up? Does it show up under the Device Manager in Windows as working properly, no error or notification messaging? All you need to do is open V8 S&T, have the drivers installed, and have the AC plugged in, no need to actually run HAPI (V8 S&T should trigger it).
    Have you tried a different USB cable? Any A to B cable should work.
    Have you tried a different PC?
  1. OBD2 Connection Problem
    By Gordy M in forum Petrol / Gas
    Last Post: September 19th, 2017, 08:29 AM
  2. ECM Connection problem
    By Tazllc in forum Duramax LB7
    Last Post: April 26th, 2014, 02:29 AM
  3. connection problem
    By 98RedZone in forum General (Petrol, Gas, Ethanol)
    Last Post: May 8th, 2007, 03:20 PM
  4. EFILive Connection Problem
    By jogasz28 in forum General
    Last Post: November 11th, 2006, 09:11 AM
