Story tuned most of the VE table put car into closed loop speed density. Car ran pretty good at part throttle not ranging to far from 14.63. Mat the gas goes lean real lean mmmm. So I added fuel to the PE table still went lean same lean. Switched back to Auto VE tuning mat the gas same lean ? I observed the injector duty cycle bank one goes to 200% and bank 2 is 18 WTF noid lighted all harnesses there all good. I have SVO 30's 64psi fuel pressure racetronix 255l pump Im going to switch back to the stock 28's when I have time I don't know mabe bad injectors Anyone have any ideas suggestions Car didn't have the problem untill the last couple days.
