Results 1 to 7 of 7
Thread: 01 to 02 conversion - no starts
    Lifetime Member Max Power's Avatar
    Nov 2005
    Default 01 to 02 conversion - no starts
    I converted a friends truck from 01 OS to an 02 DSP2 OS.
    He is getting no starts as well as the classic oil life not resetting. He is also having trouble getting his fuel tank to read properly.
    Any ideas?
    09 LMM Duramax
    Nov 2005
    Are 01 DSP2's available that remove the speed limiter?
    09 LMM Duramax
    Was all this was done using the latest version of the software?.
    I hope to finish off the 2001 DSPĀ² tonight, I'll just do one I think.
    Nov 2005
    Not sure but I am pretty sure it was done with the latest version. By software you mean the latest version of EFI live?
    Will the 01 dsp2 remove the speed limiter?
    09 LMM Duramax
    Are you talking about Doug's truck?, if yes I am dealing with him via Email.
    Yes, I meant the latest software released.
    Yes, DSPĀ² will take care of the 01 limiter, actually, you can remove it from the standard O.S, it's the Max fuel vs Speed table that is the problem.
    Nov 2005
    Yes doug.
    I'll stay out of it then
    09 LMM Duramax
    EFILive Distributor Trippin's Avatar
    May 2004
    Have you checked for codes? Is VAT disabled? My guess is "Theft deterrent" code is the reason for no start. If VAT is disabled, try flashing a tune in it with VAT enabled. Then another with it disabled.
    It seems random on my truck but this is the procedure I have used.
    www.socaldiesel.com
    EFILive-DSP5......Switch your Attitude!
    EFILive-CSP5......The Smart Way To Switch Your Cummins Tunes!
    EFILive-DSP4......Switch Your Colorado and Canyon Too!
  1. Car starts but won't stay running
    By brianjw4 in forum Gen III V8 Specific
    Last Post: April 10th, 2009, 10:37 AM
  2. Loaded Custom OS: 03Z06..starts/dies after 1 sec
    By Earl H in forum Custom Operating Systems
    Last Post: May 7th, 2007, 08:55 AM
  3. starts for 1 sec and then dies
    By Cablebandit in forum Custom Operating Systems
    Last Post: April 8th, 2007, 12:32 PM
  4. Cold Start: Starts and stalls...
    By 808ws6 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 20th, 2007, 08:34 PM
