Results 1 to 10 of 18
Thread: E38 log after setting up for vve adjustments, crazy afrs
    Jan 2018
    Default E38 log after setting up for vve adjustments, crazy afrs
    Hey guys, I have followed the swingtan and efilive autove tutorials to the T, read them and alot of other stuff over but have just applied the new calibrations so I can make a log to apply to the vve table and the wideband is showing afrs so high and low that I am wondering if I missed something or if it has something to do with another issue Im dealing with. If someone could check out the log, this is with all of the pids changed in the tutorials and the maf wire unplugged. Thanks
    Ps I am aware that there are some bad pids on there I just added to check out and the log is short because the lambda hit 1.400 and that scared me at only 1800 rpm.
    Jan 2018
    heres the tune file as well its a 2011 camaro 2ss
    If you can, post some screehshots so we can see your steps
    ( www.getgreenshot.org can help with screenshots and annotating them )
    Jan 2018
    Ok, so I took screen pics of ll the setting I changed as instructed in the tutorials. Ill put them in the best order that I did in that I can. I drove the car and got it up to temps, shut it off, unplugged the maf and uploaded the calibrations, then started and took the above log. Ive done the tutorials 3 times now and then compared the tunes and I am pretty sure I'm following them correctly, is it possible that my ve table is that far out? When I run the car on my base tune the idle sucks, but driving is alright and my stft go between -4 and +7 with ltft within 4.
    Jan 2018
    deleted
    Aug 2013
    I hate being the bearer of bad news, but there's something you should know about.... the E38 controller suffers from a thing called "rich after flash". It happens when you flash in a new calibration on a hot engine. There is no 'fix' for this... you just have to drive it out (some say 10min drive, some say 20mins, some say a few hard accelerations shortens the time... I really don't know exactly how long it takes for the richness to wash out). You can do lots of reading about it over on the HPtuners forum. Enjoy!
    Jan 2018
    Running rich is fine, its the super lean reading I was worried about when stoich is commanded. I sat in the car for a good 10 minutes after the reflash to let everything get back to normal temps, its -5 here on canada Anyways was just looking for a second look is all to see if I missed anything, a few pics didnt load for some reason of the other steps ill post when i get home
    Photobucket is not showing your pics...
    just post the pics directly in the reply (see the "framed tree" button, 3rd from right in the Reply box).
    Jan 2018
    pics. ps, when I log sae.fueltype it and it shows methanol.... is there any chance that the car is using the ethanol tables for some reason? would it hurt to change them ill never run ethanol anyways...
ID:	21951   Click image for larger version.
ID:	21952   Click image for larger version.
ID:	21953   Click image for larger version.
ID:	21954   Click image for larger version.
ID:	21956   Click image for larger version.
ID:	21957   Click image for larger version.
ID:	21958   Click image for larger version.
ID:	21959   Click image for larger version.
ID:	21961   Click image for larger version.
ID:	21962   Click image for larger version.
ID:	21963   Click image for larger version.
ID:	21964   Click image for larger version.
    Jan 2018
    rest
ID:	21968   Click image for larger version.
ID:	21967   Click image for larger version.
ID:	21966   Click image for larger version.
  1. E38 Tune Adjustments
    By Nabraxas in forum E37, E38 & E67 PFI ECM's
    Last Post: July 16th, 2013, 05:40 PM
  2. Please help me tweak my E38 VVE.
    By Jayrcr3 in forum E37, E38 & E67 PFI ECM's
    Last Post: November 30th, 2011, 07:40 PM
  3. Need E38 VVE tuning help
    By 2007chevy5.3l in forum E37, E38 & E67 PFI ECM's
    Last Post: November 26th, 2011, 08:34 PM
  4. E38 afm vve
    By VEGASROBBI in forum E37, E38 & E67 PFI ECM's
    Last Post: March 1st, 2010, 06:40 PM
  5. O2 sensor question when Setting VVE
    By alian in forum E37, E38 & E67 PFI ECM's
    Last Post: October 5th, 2008, 11:40 PM
