Results 1 to 2 of 2
Thread: Larger fuel tank and range left recalibration
    Jul 2005
    Default Larger fuel tank and range left recalibration
    please delete, moved to correct forum thanks big CE
    Aug 2014
    This is the wrong section for your question. Your truck falls into the 2011+ LML section.
    However I don't think it is possible with EFI, it might even be part of the BCM in which case you are out of luck, dealer might be able to help.
  1. Replies: 1
    Last Post: September 22nd, 2010, 03:40 AM
  2. changed fuel tank size
    By evilspyder66 in forum General (Diesel)
    Last Post: March 29th, 2009, 01:33 PM
  3. 159 litre fuel tank???
    Last Post: April 8th, 2007, 09:49 AM
  4. Fuel Tank Parameters
    Last Post: April 7th, 2007, 11:57 PM
  5. Adjusting fuel tank measurements?
    By Garry in forum General (Petrol, Gas, Ethanol)
    Last Post: July 20th, 2006, 09:53 PM
