Results 1 to 3 of 3
Thread: V2 AD Inputs Stopped Working
    Junior Member PHLTHS's Avatar
    Dec 2014
    Default V2 AD Inputs Stopped Working
    Hi All
    For some reason all of my AD inputs have stopped working. I have tried to rebuild the V2's config files again using the software. Tried reflashing the BBX etc.
    When I start to log the PID is there but its just registering 0.00V. I remember when I use to pull the input out during logging it would always show 0.10v but now it shows nothing.
    I'm not sure if I have to send it back to EFI for repairs, so I figured I'd ask the community.
    P.S I've also tested my AEM WB with a multimeter and it is sending an output etc.
    Any help would be appreciated.
    Thank you.
    HSV W427 / HSV SportsCat SV
    The A/D calibrations may have been lost/deleted whihc will cause the 0-5V value displayed by FlashScan to not match the actual raw A/D counts. You can check the raw A/D input counts by using the option on FlashScan: F4: Options -> F4 F4 Self Tests -> F4 (factory tests - menu not shown but F4 will select it anyway). Then press [Ok] to the next window about ALD, VPW and CAN testing.
    The 4 values onm the second last row of the display will show the raw A/D counts. They should show values less than about 5 counts =V and somewhere around 600-700 counts = 5V. If those values are changing in response to various voltages applied to the 5V inputs, then the A/D inputs need to be re-calibrated. You can do that using the EFILive V8 Control Panel on the [F5: Calibrate A/D] tab page. Click the [Info] button on that page for instructions.
    If the A/D counts do not change when a voltage is applied to the orange 5V inputs, then you may need to send it back to EFILive in NZ for repair. Contact support@efilive.com for more info on how to do that.
    Dec 2014
    Hi Paul
    Thank you for getting back to my post.
    I think I'm in luck. I've completed the test you said and I can see the counts changing but I cannot see anything that =V.
    I've attached a picture of the test, can you please tell if all looks ok and I'll just perform the recalibration?
    Thank you for your time.
  1. Fuel gauge stopped working after 04 LS1 swap into 99 truck
    By bubba68ss in forum Gen III V8 Specific
    Last Post: November 15th, 2016, 08:28 PM
  2. Replies: 14
    Last Post: June 20th, 2016, 04:53 AM
  3. Analog inputs not working
    By Camaro SS in forum External A/D inputs
    Last Post: August 7th, 2013, 06:55 AM
  4. External inputs not working...
    By Wolverine in forum External A/D inputs
    Last Post: September 26th, 2011, 05:26 AM
  5. My V1 stopped working!!!!!
    By RandyWS6 in forum FlashScan V1
    Last Post: August 5th, 2008, 02:25 AM
