Thread: 411 ecu with 98 Vette pedal tac and ls2 tbody issues
    Dec 2008
    Default 411 ecu with 98 Vette pedal tac and ls2 tbody issues
    As title says,having some issues,custom 2 bar os runs and drives perfect,fueling isn't spot on yet but close enough to drive.anything more then 10psi and it goes into limp mode.base file I started with was a 2156 02 Vette auto that a did a trans segiment swap for a 4l60 from Camaro so it doesn't think it's a trans axle.runs and drives great.ive raised every airflow table I can find some more then needed I'm sure.can someone smarter then me chime in with some tips or info.thanks alot.
    Are you running a MAF...?
    Dec 2008
    No straight sd 2 bar
    Dec 2014
    Can you post a tune file?
    Dec 2008
    Quote Originally Posted by Team208Motorsports View Post
    not ATM at the movies with my son.
    Dec 2014
    I'd check ETC conversion scalar for the new TB. Log TPS' and see if they are affected from boost.
  1. Does the 411 ECM care whether it's a Corvette or a truck TAC?
    By Jim in forum Conversions / Aftermarket Parts
    Last Post: September 4th, 2017, 01:59 AM
  2. Anyone done a mech tbody on a e38 08 vette os?
    By AllOutPerformance in forum E37, E38 & E67 PFI ECM's
    Last Post: January 21st, 2012, 06:59 AM
  3. holden vz ls1 tac - pedal part numbers
    By JCA in forum General
    Last Post: December 30th, 2010, 10:16 AM
  4. Pedal position vs. commanded TAC position weirdness
    By gmtech16450yz in forum E37, E38 & E67 PFI ECM's
    Last Post: November 1st, 2009, 12:48 PM
  5. DBW pedal and TAC module differences
    By DURAtotheMAX in forum Gen III V8 Specific
    Last Post: September 17th, 2009, 06:09 PM
