Results 1 to 5 of 5
Thread: Is this normal for VE tuning
    May 2006
    Default Is this normal for VE tuning
    Say part throttle im staying around 14.7 to 1 and if I just punch it it will go to say above 20 to 1. In SD mode does the computer use PE at all even when you return to closed loop SD? Any info appreciated
    Oct 2005
    You need to make sure you have re-enabled PE mode once you have finished dialing it in. Though it should at worst go to 14.7:1 if you forgot to. Sounds like you have some other issue.
    2014 VF SV LS3 Maloo.
    Jan 2005
    is this your commanded or actual AFR that's jumping to 20:1? If it's commanded, something is not right in your tune. If it's the actuall, then yes, this can happen, but the tune needs fine tuning.
    Make sure you don't confuse your Lambdas, EQs, and AFRs! Don't ask me how I know....
    -Dennis
    2001 Z28 M6 Hardtop
    Dedicated Roadrace Car
    Recent Mods: TEA S1 Heads, 224/224 .568" 110+4 LSA Cam, QTP Headers, Flow-matched 42# Injectors
    May 2006
    its all in the default EQ ratio. I guess its in my tune but I donno Fuel system checks out ok. im going to load back in a stock tune with the maf and see if anything changes.
  1. Isthis Normal?
    By Yortt in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: February 23rd, 2008, 12:14 AM
  2. IAC issue or this is normal?
    By louis in forum General (Petrol, Gas, Ethanol)
    Last Post: November 12th, 2007, 05:34 PM
  3. what is normal operating ect?
    By Aint Skeered in forum Gen III V8 Specific
    Last Post: August 24th, 2007, 02:37 PM
  4. VE Table >100% normal?
    Last Post: December 8th, 2006, 07:38 AM
  5. Please Clarify HOT and NORMAL
    Last Post: March 8th, 2005, 09:32 AM
