Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Electronic Throttle Body issue after cam seap
    Dec 2014
    Its all off because the fuel is off. What was posted was to get it started and check for throttle body or tune issues. Do you have a wideband?
    Member TorqueMonster007's Avatar
    Aug 2013
    I have an Innovate LM-2 but is not connect to the v2. But yes the throttle body issue appears to be fixed. If it is capable (and I will check) to be hooked in line via serial port to the v-2 then I can hook it up but at the moment have not tried.
    2024 3500HD (SRW) Duramax Denali Reserve
    2021 Ram 4500 Limited (Horse Hauler)
    2016 LML 2500HD Duramax High Country with a little help
    2022 Yukon Denali
  1. Cam and Big Throttle body only.
    By rpmspeed in forum Gen III V8 Specific
    Last Post: June 2nd, 2012, 07:28 PM
  2. VZ LS1 electronic throttle
    Last Post: January 12th, 2012, 12:47 AM
  3. VZ Electronic throttle
    Last Post: December 14th, 2011, 01:18 PM
  4. How to get a 4.8 off the line if it has an electronic throttle
    By chevyman08 in forum Gen III V8 Specific
    Last Post: July 25th, 2008, 11:40 AM
  5. Electronic throttle control conversion for the F-Body?
    By leres in forum General (Petrol, Gas, Ethanol)
    Last Post: July 23rd, 2005, 08:02 AM
