Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 53
Thread: Running extremely rich in boost/breaking up
  1. #31
    Oct 2016
    I didn’t even think about the pressure difference when I changed the injectors data. I’ll get back behind the computer and start reviewing everything again.
  2. #32
    Dec 2014
    He would be better to start with a stock tune, and add in only the edits required.
    Exactly. Back to the minimal changes to get things going. Then when everything is known, tune whats needed.
  3. #33
    Oct 2016
    I started with a stock tune and converted it to cos3. Should I start again fresh and retry it?
  4. #34
    Dec 2014
    What we are saying is list out all the specs in one place. Injectors, map, fuel system, how its setup.... We'd be happy to help but everything needs to be organized together and a proper base flash needs to be built. Right now its a train wreck.
  5. #35
    Oct 2016
    Ok I’ll start with a basic cos3 build off my stock tune and get everything organized. I really do appreciate the help and I’ll repost once I’d get everything in order. Thanks again
  6. #36
    summary:
    - find stock tune with same OS;
    - do COS update from stock tune;
    - fix out-of-range tables/cells (remember exit/reopen trick);
    - set injector tables (IFR and the other tables) from data provided (using measured rail base pressure);
    - set MAP scaler/offset to match 2-bar MAP sensor;
    - set MAF to fail properly (see a MAF DTC show up);
    - set B3647 to ramp up non-boost fueling (and avoid stoich cells);
    - set B3618, B3613 to provide boost fueling;
    - reduce B5913 and B5914 spark advance to accommodate boost (what is the spark vs boost rule-of-thumb);
    - disable systems not physically present;
    what else...?
    visually inspect everything, make sure everything is connected/bolted properly, and no leaks.
  7. #37
    +1 on what Team208 said, being organized is important to tuning properly.
  8. #38
    Oct 2016
    ill start all of this later today, thanks again
  9. #39
    Oct 2016
    when setting the ifr, should i set it flat (referenced) or sloped (non-reference)?
  10. #40
    Dec 2014
    Is the rail returnless? I feel like questions keep getting asked with no answers.
  1. running rich
    By derkscustomcars in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: August 30th, 2015, 08:58 AM
  2. Breaking up in Boost Randomly
    By cyipher in forum Custom Operating Systems
    Last Post: June 5th, 2013, 03:28 AM
  3. "Breaking up" when in boost?
    By DrX in forum Gen III V8 Specific
    Last Post: August 15th, 2011, 03:40 PM
  4. Why am I running rich during PE?
    By n8dogg in forum Gen III V8 Specific
    Last Post: August 4th, 2011, 09:31 AM
  5. Why is it running rich?
    By Garry in forum Gen III V8 Specific
    Last Post: May 10th, 2008, 05:05 AM
