Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 53
Thread: Running extremely rich in boost/breaking up
  1. #21
    Team208 is saying that you want to see a MAF DTC
    ( without this, the PCM tries to calculate what MAF should be, and it's always wrong ).
    Get this sorted out first.
  2. #22
    Also, on your next log, remove pid HO2S12, and add HO2S21.
  3. #23
    Dec 2014
    The injectors you listed are flex fuel 50 lb at 4 bar.......
  4. #24
    Oct 2016
    They are GM Delphi injectors, Static Flow Rate at 43.5 PSI: 440cc/min, 42lbs/hr. I
  5. #25
    Oct 2016
    Yes 50 lb at 4 bar
  6. #26
  7. #27
    Dec 2014
    50 at 4 and you are saying you are running stock pressure....... Tune shows 42s on a return style system with stock regulator.
  8. #28
    Dec 2014
    There is too many BASE TUNE SETTINGS not setup properly to even begin to chase something wrong. The tune is fat, the injectors data is wrong. Have to have the right base to build off of, if not, you will be chasing your own tail the entire process.
  9. #29
    Measure rail pressure with FPR reference disconnected (it should be 58 psi, i.e. 4 bar);
    42 * sqrt(4/3) = 48.5 lb/hr (close enough to 50 lb/hr) = 6.11 g/s
  10. #30
    He would be better to start with a stock tune, and add in only the edits required.
  1. running rich
    By derkscustomcars in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: August 30th, 2015, 08:58 AM
  2. Breaking up in Boost Randomly
    By cyipher in forum Custom Operating Systems
    Last Post: June 5th, 2013, 03:28 AM
  3. "Breaking up" when in boost?
    By DrX in forum Gen III V8 Specific
    Last Post: August 15th, 2011, 03:40 PM
  4. Why am I running rich during PE?
    By n8dogg in forum Gen III V8 Specific
    Last Post: August 4th, 2011, 09:31 AM
  5. Why is it running rich?
    By Garry in forum Gen III V8 Specific
    Last Post: May 10th, 2008, 05:05 AM
