Results 1 to 2 of 2
Thread: Can I use the DVT setting when setting up for tuning?
    Jan 2018
    Default Can I use the DVT setting when setting up for tuning?
    I have a camaro 2011 ss E38 and have been tuning it using swingtans settings and with the random help of the best guy here mr Joecar (thx!). Anyways after months of learning and a few issues im still ironing out (damn o2 sensor tables), I have a good looking vve table and working on the maf. I have a couple of setup cal files that are made up to keep the car in OL, dfco disable, commandeds setup at stoich. Is it possible to just setup a cal file with dfco disabled, commanded all 1.0, and setup PE, then I can drive for a while with the trims taking care of my fueling while the rich after flash and what not clears up? Then just unhook the maf wire and use dvt to throw it in OL, clear the trims, shut em off and start logging? Im just using this as an example as there are lots of scenarios I can picture using the dvt, but is it fine to use it for long periods, does the car need the maf completely shut off or is just failing it by wire ok as well?
    Yes, you could do that.
  1. setting up V2 with AFX
    By turbochevytruck in forum External A/D inputs
    Last Post: January 14th, 2014, 12:28 AM
  2. Help setting up AEM WB
    By SUPERTRUCKER in forum General (Petrol, Gas, Ethanol)
    Last Post: April 18th, 2009, 10:22 AM
  3. Setting up A0014
    Last Post: April 7th, 2008, 02:00 PM
  4. Setting timing ?
    By Chuck L. in forum Vortec V6/V8 Specific
    Last Post: April 6th, 2008, 07:07 AM
  5. Setting up for Autotune with LM-1..
    By Redline Motorsports in forum General
    Last Post: July 21st, 2005, 11:29 AM
