Results 1 to 5 of 5
Thread: 1998 402 Forced Induction
    Jun 2006
    Default 1998 402 Forced Induction
    Tuned sd 7 psi will soon increase boost to 20 psi after break in. currently using MAF. I would like to upgrade OS to 2 bar MAP. C5 6 speed 402 procharger. What os should i use ? os not listed.
    Oct 2005
    98 PCM is a sad story, no custom OS available. Ross had plans, but they are on the back burner.
    2014 VF SV LS3 Maloo.
    Feb 2005
    Quote Originally Posted by MPDYNO
    What is the max maf frequency you are seeing @ 7 psi?
    99 FRC 402 Twin Turbo
    Oct 2005
    You can play with the stock OS in open loop and use PE to kick in post 105kpa for extra enrichment. Not sure on the spark front though, you might have to talk to the stock OS FI guys.
    Senior Member Chuck L.'s Avatar
    Feb 2006
    Question ????????
    What are you going to use for injectors at 20psi??
    Chuck L.
    CODY Motorsports
    Fuel Injector Service
    Madison, GA.
    706-342-3152
    770-265-5144 [C]
  1. E38 ECU, S/D operating system, forced induction. Barometeric updates?
    By Blown353 in forum Custom Operating Systems
    Last Post: November 19th, 2008, 12:48 PM
  2. spark map for forced induction????
    By 350SS in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: June 8th, 2007, 10:57 AM
  3. HELP!! 98 LS1 forced induction
    By RUTAN TA in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: August 12th, 2006, 06:04 AM
  4. Cold air induction... What a difference!
    Last Post: May 16th, 2006, 10:52 AM
