Results 1 to 10 of 10
Thread: turn on readiness monitors
    May 2008
    Default turn on readiness monitors
    i have a 06 6.0 in my jeep, i have obd2 testing. i have a working tune but all the readiness monitors seem to be set to not available.
    does anyone know exactly what Engine DTC Processing Enablers control witch readiness monitors?
    https://docs.google.com/spreadsheets...it?usp=sharing
    Jan 2010
    Can you post the tune file?
    Or at least let us know what calibration you are working with?
    May 2008
    Quote Originally Posted by 1FastBrick View Post
    jp-6l-5sp-SILV_0004.ctz
    May 2008
    does anyone know? need to send this in for etest, i guess i could try wit them all turned off, but i assume they will expect some of the monitors to be on.
    I looked at your .ctz and it seems to me that some of the readiness tests should be available...
    what vehicle did your 12593058 file come from...?
    can you start with a stock 12593058 file and copy your tables over...?
    May 2008
    i got the stock file off one of the efilive tuners because it was difficult to find a lq4 + nv4500 manual file online. when i got it i noticed it wasn't a factory flash as a lot of the Engine DTC Processing Enablers were turned off that would be on in a factory dump
    i guess i could use a lq4 + 4l80e stock file and try to change it over to nv4500
    the engine is from a van/ the harness is home built, i added in the tac wiring as i wanted to be able to have cruise, the trans is from a 2500 manual truck.
    may be best to find the latest os that supports my tac.
    Jan 2010
    Quote Originally Posted by akafred View Post
    I am not sure what that file came from originally with out an original vin.
    I do happen to have 2 stock 2004 6.0L with Manual Transmission files you may be able to use assuming your emissions equipment is in tact.
    Jan 2010
    I just thought of something else.
    I am not sure what Pedal and tach module you have. If it's an all plastic pedal thats 06,07 classic and will not work with an 03-05 calibration. The 03-05 are metal with a plastic foot pad.
    Jun 2018
    anyone figure this out, in terms of adding readiness monitors? I need to enable EGR.
    I might have to reflash it too a 2000 camaro or something else with it built in I think.
    May 2008
    Sent u a email
  1. Need help with Readiness Monitors
    By ScarabEpic22 in forum E37, E38 & E67 PFI ECM's
    Last Post: April 16th, 2013, 10:41 AM
  2. Poll; how many use large monitors for tuning?
    By Chevy366 in forum Lounge
    Last Post: July 8th, 2012, 05:13 AM
  3. OBD II readiness
    By frcfed347 in forum E37, E38 & E67 PFI ECM's
    Last Post: March 7th, 2011, 02:32 PM
  4. Air-Fuel Ratio Monitors
    By Sid447 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 24th, 2009, 09:45 PM
  5. OBDII readiness monitors
    By edcmat-l1 in forum Gen III V8 Specific
    Last Post: September 25th, 2008, 12:05 PM
