Results 1 to 4 of 4
Thread: 2010 Emissions Compliant EFI Tuning
    Apr 2018
    Default 2010 Emissions Compliant EFI Tuning
    Hey everyone! First time posting here, usually I’m over on Cummins Forum a bit of the time. I’m having issues with some emissions compliant tunes from my current tuner. I’m not here to bash the tuner company. I’m looking to see if anyone else has had a similar issue.
    My truck runs and performs all functions properly on a stock tune. As soon as I flash a set of 4 tunes or even a single tune in my truck. I run it for say 30-50 miles and the truck commands a regen. The engine does not actually perform the regen however, just commands it. I can tell there is no post injection events occurring since my NOX and DPF temps don’t rise above normal driving temps. I will get codes P0420 and P24A0. I then flash the truck to stock, drive it and let it perform a Regen. I’ve had a few different revisions sent to me, with all doing the exact same thing.
    I switched tuning companies when this all began. Is there anything I could be doing wrong via email, uploading the tunes to my autocal, etc? Should I be trying pass through flashing? Or is this just a silly issue with the tuner/tuning?
    Thanks in advance!
    Apr 2018
    Edited post, didn’t realize it didn’t all go through
    Dec 2005
    There is, IMHO, no such thing as what you have purchased, STOCK Tunes are compliant, if the tuning you purchased is not EPA/CARB certified then its in no way "Compliant".
    I would talk with your tuner and express your concerns and ask them to look over what you were sold and possibly work towards a solution.
    But just because you did not actually remove your components, does not mean you purchased anything compliant.
    Just ask VW, they can tell you how it worked out for them.
    www.mscservices.net
    Apr 2018
    Maybe I should say Emissions Present Tuning instead of Compliant, my bad!
  1. 2012 cummins emissions removal with efi
    By Cwalt50 in forum Cummins 6.7L
    Last Post: December 9th, 2015, 07:53 PM
  2. EFI Live Tuning and passing emissions testing in Califoria?
    By blades11b in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 14th, 2015, 06:34 AM
  3. emissions related tuning?
    By C Murda in forum General (Diesel)
    Last Post: April 8th, 2013, 11:03 AM
  4. J-2534 Compliant
    By L31Sleeper in forum FlashScan V2
    Last Post: December 7th, 2010, 09:50 PM
  5. Passed nc emissions but efi shows -not ready
    By dbaxter_ss in forum General (Petrol, Gas, Ethanol)
    Last Post: May 27th, 2005, 11:44 AM
