Results 1 to 4 of 4
Thread: E92 fan relay control?
    Jul 2012
    Default E92 fan relay control?
    Is it common knowledge that the e92 ecms cannot support series/parallel fan relays in the traditional sense? Perhaps I am the last to know. They look to be PWM only, or am I missing something? I didn't see a Patch either.
    Dec 2014
    PWM only.
    Jul 2012
    So the next question is what PWM fan controller should we use? I hear that some have used a corvette controller, but I haven't found any more specifics. I am fairly familiar with the C6 controller as I had to replace one that was damaged once. Is there any reason on of these wouldn't work with the e92? AC Delco 1580803
    Dec 2014
    That’s up to you. Personally I’ve used many different ones, even a Chrysler one from grand cherokees.
  1. Replies: 12
    Last Post: March 9th, 2018, 06:46 AM
  2. When the E92 fan tuning will be available ?
    By wesam in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: February 25th, 2014, 11:10 AM
  3. Using the AC relay output to control a second fuel pump
    By ttls1 in forum Gen IV V8 Specific
    Last Post: December 31st, 2013, 11:13 PM
  4. Replies: 8
    Last Post: August 22nd, 2011, 12:08 PM
  5. fan control
    By Naf in forum E37, E38 & E67 PFI ECM's
    Last Post: January 31st, 2011, 01:26 AM
