Results 1 to 8 of 8
Thread: Allison A42 Support?
    Sep 2017
    Default Allison A42 Support?
    I have searched this forum for any sign of support for an A42 TCM without success
    Would I be able to tune my A42 TCM with EFI Live?
    Attached is the CIN info
    Thanks in advance, Jerry
    Probably no, not even sure what the A42 is in the range of Allison TCM's. Is that on Silverado's or non GM vehicles?
    Sep 2017
    Thanks for the reply
    The A42 would be non GM. It is an Allison TCM for a stand alone 1000 in an industrial application.
    Will try to connect but looking at the CIN details I will probably not waste too much time playing around with it...
    I'm guessing given the application the A42 is probably J1939 only, the Allison tuning and communications in EFILive is for GM vehicles only.
    Sep 2017
    It is J1939 for sure so I will not waste any time in that case.
    Thanks again,
    Jerry
    Dec 2013
    All 4th gen TCMs have CAN1 J1939 and CAN2 GMLAN connections. I have a couple T42s I have wished were supported, they detect and read with EFI live just fine but of course the OS is unsupported. I hoped and assume that the mapping is identical to the A40 and that it would just be a OS number being added to a definition list, I dunno
    I can get a read and post it here if its worth you guys time to see if it's that easy.
    Medium duty Allison tuning is becoming important with the HD Cummins tuning being available now.
    We did get a few Allison TCM's last year to look over (A41, A43, A51, A53), one of them had Allison software in it but no identifier of what OS or Cal was in it, there was nothing.
    I am sure the mapping or at least the control concepts would be similar to the GM versions but that doesn't mean it would be simple task by any means.
    Jul 2017
    +1 for interest in A51.
    I have an A41 that I tune with EFI all the time and it seems pretty accurate.. im not sure in my application where the Pattern A,B,C,D apply however im able to edit the shift points and TCC parameters without issue.. it as mentioned before.. CAN1 is J1939 and talks to my Navistar T444E ECM for throttle and engine load info.. CAN2 is GMLAN and where I talk to EFI from.
    I did a read / flash with Allison PCCS to copy and write my calibration to another A41 TCM which tyhen became tuneable with EFI after I reflashed it.. so it seems A41 works whether officially suppoorted or not..
    I have an A51 whuich EFIlive can read the "dashboard" however I have no ability to read / write the Cal on it.. Id rather be running my A51 as it supports J1939 TAP shifting. whereas my A41 does not.. my A41 is aware the J1939 is being sent, however the allison Datapoint "wire" isnt mapped to a function in that TCM where it is in the A51..
    my allison DOC premium and PCCS dont allow me to add / delete wires / datapoints or edit the calibrations..
    -Christopher
  1. flashing 6spd allison os into 5spd allison tcm
    By Scarface in forum Allison 5 & 6 Speed
    Last Post: 2 Weeks Ago, 05:30 AM
  2. 03 allison
    By minytrker in forum Allison 5 & 6 Speed
    Last Post: May 3rd, 2010, 04:16 AM
  3. 8.1 with allison in RV
    By minytrker in forum Vortec V6/V8 Specific
    Last Post: August 6th, 2009, 06:29 PM
  4. Allison transmission
    By Whippled 496 in forum Duramax LB7
    Last Post: September 25th, 2006, 07:30 AM
  5. allison
    By maxium overdrive in forum Duramax LLY
    Last Post: July 13th, 2006, 10:11 AM
