I could be wrong here but when inHG is used for MAP shouldnt 0 be wide open throttle and ~15inHG be at idle like a vacuum gauge? When using EIlive it displays idle close to 0inHG and WOT ~20inHG - seems backwards. I know kPA is the other way around (higher numbers for less vacuum). Just curious if my logic is off
