Results 1 to 5 of 5
Thread: Imperial MAP values seem backwards
    Jun 2004
    Default Imperial MAP values seem backwards
    I could be wrong here but when inHG is used for MAP shouldnt 0 be wide open throttle and ~15inHG be at idle like a vacuum gauge? When using EIlive it displays idle close to 0inHG and WOT ~20inHG - seems backwards. I know kPA is the other way around (higher numbers for less vacuum). Just curious if my logic is off
    Jul 2004
    oppps
    Measuring air pressure can be done in different ways:
    1. as absolute pressure.
    2. as gauge pressure wrt to atmosphere.
    3. as vacuum wrt atmosphere.
    The units (Metric or Imperial) do not influence how the measurement should be made. i.e. a measurement in kPa is *exactly* the same as a measurement in inHg.
    The formula for converting between kPa and inHg is:
    1kPa = 0.295299875 inHg
    so
    0 kPa = 0 inHg
    50 kPa = 14.8 inHg
    100 kPa = 29.5 inHg
    101.3 kPa = 29.9 inHg = 1 atmosphere = 1 bar
    Regardless of what units are used to measure it, the OBDII manifold pressure is always measured as an absolute pressure. That is defined by the SAE and is part of the OBDII speification.
    The acronym MAP means literally, Manifold Absolute Pressure.
    Which is measured with respect to 0 being the pefect vacuum.
    Hope I did not confuse the issue even more.
    Lifetime Member Bruce Melton's Avatar
    Oct 2003
    Default Re: Imperial MAP values seem backwards
    Quote Originally Posted by kp
    I was just reading mine via Scantool and ran from 13inHG/44Kpa at idle, ~11inHG/37kpa at light throttle and 29.5/99 at WOT which I hope is "normal"??
    PowrMax Performance
    100 mm PowrMAF
    Jun 2004
    You are right Paul, after 25 years of looking at vacuum gauges it is correct the way its converted. Absolute pressure is not manifold vacuum.
    Technically, inHG of vacuum is what a typical vacuum gauge reads and thats where I got confused. Also the Gen7 stuff I have been working with lately lists the VE table using kPA or inHG VAC so it looked correct to me there compared to a vacuum gauge.
    In other words, never mind
  1. Imperial pids for BBL?
    By thunderstruck507 in forum Black Box Logging
    Last Post: February 9th, 2010, 03:04 PM
  2. Question displaying Imperial during BBL
    By Brian1 in forum FlashScan V2 BB Logging
    Last Post: November 8th, 2009, 01:15 PM
  3. Imperial vs Metric
    By killerbee in forum General (Diesel)
    Last Post: September 3rd, 2009, 08:16 AM
  4. Going backwards to go forward?
    By XLR8NSS in forum FlashScan V2 BB Logging
    Last Post: December 18th, 2007, 06:29 PM
  5. DESIAC_B values and MAF values keep trimming down. Help!
    By ArKay99 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 12th, 2005, 12:54 PM
