Results 1 to 5 of 5
Thread: 90 lb/ hr DW Injector Tables Scaling
    Apr 2012
    Default 90 lb/ hr DW Injector Tables Scaling
    Would someone please look at the attached tune and 90 lb inj tables from DW and see if I scaled them correctly in my E38. Also where to start (%) in the VE 2 Bwr Tables?
    Procharger9+ 2 Bar Map_0000.ctzGM injector data 16u-90 with offsets inverted modified.xls
    I'll take a look later today.
    Apr 2012
    I am sure you are busy with all of the units out there and people asking questions, but please take a look when you have time. I read another post where you used a singls scaled number in all cells and then used manifold referenced vacuum. Is this a better way to go?
    LBL866
    I am sorry I got loaded up with some emergency family stuff...
    I'll still take a look, possibly tomorrow.
    Apr 2012
    I sure do need your advice. Prepping for an event and am stuck😱
    LBL866
  1. Replies: 10
    Last Post: September 27th, 2013, 12:25 AM
  2. Injector scaling.
    By PRAY in forum FlashScan V1
    Last Post: June 24th, 2011, 10:25 AM
  3. Where is the injector scaling table?
    By PRAY in forum Gen III V8 Specific
    Last Post: January 2nd, 2009, 01:34 PM
  4. Injector scaling question. Which rate to use
    By ViolatorTA in forum General (Petrol, Gas, Ethanol)
    Last Post: June 15th, 2006, 02:19 AM
  5. Injector scaling question for Motron 60's..
    By Redline Motorsports in forum General (Petrol, Gas, Ethanol)
    Last Post: April 3rd, 2006, 06:19 AM
