Results 1 to 10 of 15
Thread: E38 and aftermarket speedometer settings
    Jul 2012
    Default E38 and aftermarket speedometer settings
    I'm not sure why I haven't run into this before, but I'm having trouble getting the speedometer to do *anything* in an L99 swapped classic. Many of the e38 swaps I deal with use OBDii interfaces for the gauges, this one is using Dakota digital VHX which utilizes the single output wire from the ecm into their box. I've done this several times with LS1B ecms so I am familiar with the gauges themselves but for whatever reason this e38 is giving me issues.
    There is a single signal wire going from ECM X1 pin 57 like everyone says to do. I've tried basically every combination of settings within reason on the bottom 6 setting boxes. Searching has turned up very little.
    2010 Camaro L99 E38 with 6L t43, all stock engine and trans. Aftermarket harness and wiring and pins have been verified. I can watch speedo data on the scan tool so the info is getting into the Can-bus I just can't seem to get it out of the ecm and into the gauge. Click image for larger version.
Name:	e38 Speedo.JPG
    Jul 2012
    Anybody? Would I be better off asking this question in a different section?
    Did you try using a pull up resistor in the circuit ? Not sure if is necessary or not.
    Al
    Dec 2007
    The cal is set for serial data in the image - is that what you have set it up for?
    im running a similar setup in a conversion.
    I had to do a pullup resister on the tacho & vss signal. Unfortunatly in my case, the ppk value is still much lower then what i needed for my speedo to read correctly so i had to fudge the shit out of the calibration. So now when working on shift speeds you need to log vss from the trans & not the ecu.
    so i had a look at mine, change your h0164 to can late. do the pull resister on the line and report back
    Jul 2012
    OK, thanks! So a pullup resistor to power, correct (not pull down to ground or anything like that)? 1000 ohm good enough?
    1.2 kohm might be easier to find.
    Jul 2012
    I've tried everything above, settings and pullup resistor, no luck. I even tried a different aftermarket speedo that I know works. I found this thread, am I simply dealing with an OS that won't support it?
    2010 Camaro L99 12637084 OS
    https://forum.efilive.com/showthread...t-Constant-12v
    Mar 2007
    From my looking at LS1B OS's, my guess is that there is a setting in the System segment which controls it. There are quite a few different settings which are not mapped out in EFILive. If you had a copy of both binary files, it might give you something to play with in terms of where the differences are.
  1. E38 LTFT operation and RPM/MAP Boudary settings
    By mowton in forum E37, E38 & E67 PFI ECM's
    Last Post: December 24th, 2015, 02:16 AM
  2. E38 G0901 Table for Fans settings
    By Chalky in forum FlashScan V2
    Last Post: April 17th, 2015, 03:06 PM
  3. E38 Speedometer Correction
    By minytrker in forum E37, E38 & E67 PFI ECM's
    Last Post: June 8th, 2012, 03:05 AM
  4. E38 60lb injector settings.
    By rally1 in forum E37, E38 & E67 PFI ECM's
    Last Post: March 25th, 2011, 01:22 PM
  5. Fan settings E38
    By eboggs_jkvl in forum E37, E38 & E67 PFI ECM's
    Last Post: August 14th, 2008, 11:15 PM
