Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: E38 and aftermarket speedometer settings
    Jul 2012
    Heres my tune file if anybody cares to find something I've missed. Engine and trans are stock as far as I know.
    E38 2010 Camaro 12637084 Modified.ctz
    send me a pm with your email. I will email you the ecm/tcm tune i used in my conversion.
    Jul 2012
    pm sent, thank you!
    Jul 2012
    Tre-cool, I didn't get a chance to load your tune but I'm assuming it works. On that same day a friend emailed me a bone stock vette file that fit in the compatibility column. I figured I'd start with the cleanest slate I could. I made the basic VATS changed and loaded it and the speedo worked (not accurate yet, but it moves)! I still have the resistor in place from before. I am considering removing the resistor and see if it still works then maybe load yours as well. Maybe I'll do a little experimenting to see if I can make some sense of all this. Why do some E38 systems work and some not, etc. I guess its part of the software in the background that EFILive doesn't give us access to??? Maybe this info will help others. Do NONE of the truck and Camaro e38s work, only the ones from a vette, due to the background settings?
    Thanks for the help guys.
Name:	e38 Speedo Settings.JPG
    well when i played with mine. i tried the camaro e38 os for both the ecu/trans & couldnt get the tapshift to work as a hardwire.
    but the holden ecu tune with the camaro tcm base would work. so go figure.
  1. E38 LTFT operation and RPM/MAP Boudary settings
    By mowton in forum E37, E38 & E67 PFI ECM's
    Last Post: December 24th, 2015, 02:16 AM
  2. E38 G0901 Table for Fans settings
    By Chalky in forum FlashScan V2
    Last Post: April 17th, 2015, 03:06 PM
  3. E38 Speedometer Correction
    By minytrker in forum E37, E38 & E67 PFI ECM's
    Last Post: June 8th, 2012, 03:05 AM
  4. E38 60lb injector settings.
    By rally1 in forum E37, E38 & E67 PFI ECM's
    Last Post: March 25th, 2011, 01:22 PM
  5. Fan settings E38
    By eboggs_jkvl in forum E37, E38 & E67 PFI ECM's
    Last Post: August 14th, 2008, 11:15 PM
