Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Magnacharged 04 Silverado 6.0 too lean?
  1. #21
    Jan 2007
    Here is the current tune file. I know i can run analog, I just haven't tuned anything in so long I also don't have my terminals for the analog input pins. I ordered another Serial cable.
  2. #22
    Jan 2007
    I was finally able to log my AFR, I could only log it in Lambada, for some reason when I used AFR it was all over the map. not sure what was going on with that. possibly the adapter to the PLX? I wish I would have gone with a different brand WBO2...
  3. #23
    You can drop the pid GM.AFR and log GM.EQIVRATIO instead...
    this goes nicely with WO2LAM1 (since the the BEN is GM.EQIVRATIO * EXT.WO2LAM1)
    ( and avoids having to account for the differences in stoich AFR )
    Also, for tuning, to keep the pid channel count no larger then 24, drop another pid, GM.DYNCYLAIR_DMA (since you're logging GM.DYNCYLAIR).
  1. 2003 Silverado Going lean?
    By kostelacd69 in forum Gen III V8 Specific
    Last Post: August 1st, 2016, 03:17 AM
  2. turbo Silverado lean spikes/stumble
    By BLK02WS6 in forum E37, E38 & E67 PFI ECM's
    Last Post: June 11th, 2016, 01:38 PM
  3. Magnacharged LS2 tune?
    By rags in forum Gen IV V8 Specific
    Last Post: September 27th, 2012, 09:56 AM
  4. Lean Cruise for a 09 Silverado
    By PACougar in forum Gen III V8 Specific
    Last Post: June 3rd, 2011, 08:19 AM
  5. 2001 Silverado 2wd PCM into 2000 Silverado 4wd
    By LastCall in forum Gen III V8 Specific
    Last Post: April 20th, 2011, 12:52 PM
