Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Magnacharged 04 Silverado 6.0 too lean?
    Jan 2007
    Default Magnacharged 04 Silverado 6.0 too lean?
    So I purchased a Magnacharger TVS1900 for more towing power on my 04 2500HD used the included SCT to flash it, and now I want to fine tune it properly. I have read that safe AFR for FI is around 11-11.8? I'm using 93 octane from the pump, I just installed my WBO2 and I am reading around 12-12.4 WOT. So I haven't been stepping in to it at all till I get this figured out, is 12.4 too lean? I assume its because the kit is for a stock engine and I have a CAI and a Cat back. Also the kit uses the stock 1 bar MAP sensor, shouldn't it use a 2 bar? I ordered a 2 bar with hopes of converting to a custom OS or would I be wasting my time doing all this? The truck runs great and has a ton more power than it had but I am afraid I am running too lean. I can post up a log file once I get my WBO2 connected to my flashscan (PLX had to order the TTL to serial adapter)
    Let me know what you think.
    Thanks.
    AFR 11.6 (EQR 1.26) is safe.
    AFR 12.4 is too lean.
    Use the 2-bar sensor (set the map scaler);
    is it Gen3 or Gen4...?
    if it's a Gen3 there might be a COS, see the document Custom OS Upgrade Tutorial - LS1.pdf in the folder C:\Program Files (x86)\EFILive\V7.5\Doc\Tutorials.
    if it's a Gen4 then its an E38, this already has a 2-bar VVE table.
    Jan 2007
    Its a Gen 3, My bad on posting in the wrong section, can the post be moved to the correct gen 3 section? I will get to work on the COS as soon as I get my 2 bar MAP sensor.
    Jan 2007
    I was reading the COS Tutorial and it says to disable the MAF, can the MAF not be used with a COS?
    Jan 2007
    In the mean time till I get my 2bar and my TTL 232 adapter is there something I can do in the current tune to give it more fuel so I am not running lean? I have attached my current tune.
    No worries, I moved your thread to the Gen3 section.
    Quote Originally Posted by s10mods View Post
    Disabling the MAF is for tuning the VE (the COS has special feature to retain the HO/LO adaptive spark in presence of MAF DTC).
    You can run the COS with MAF.
    Increase table B0101 (VE) in areas where you make boost... increase say 30% and do a test drive, analyze the log to see if you need more/less air (fuel is added in ratio to air).
    Aug 2013
    From what I see in your tune file, you appear to be running a return style fuel system. Save yourself a lot of heartache and install a boost referenced fuel pressure regulator. In the meantime, don't drive the engine too hard.
    Jan 2007
    Quote Originally Posted by statesman View Post
    That's the bad thing, this is how the tune came from Magnacharger and I have a returnless fuel system. I dont know what the IFR table should be set to, but I know its not flat. In the kit it suggested to get the pcm reflashed to stock and I did that. attached is my stock file, the only changes I have made to the Maggie file are some trans shift parameters, remove vats and recal the speedo. I have no idea why they would have the IFR table the way it is but I will need to correct that in my new 2bar tune also.
  1. 2003 Silverado Going lean?
    By kostelacd69 in forum Gen III V8 Specific
    Last Post: August 1st, 2016, 03:17 AM
  2. turbo Silverado lean spikes/stumble
    By BLK02WS6 in forum E37, E38 & E67 PFI ECM's
    Last Post: June 11th, 2016, 01:38 PM
  3. Magnacharged LS2 tune?
    By rags in forum Gen IV V8 Specific
    Last Post: September 27th, 2012, 09:56 AM
  4. Lean Cruise for a 09 Silverado
    By PACougar in forum Gen III V8 Specific
    Last Post: June 3rd, 2011, 08:19 AM
  5. 2001 Silverado 2wd PCM into 2000 Silverado 4wd
    By LastCall in forum Gen III V8 Specific
    Last Post: April 20th, 2011, 12:52 PM
