Thread: $0534
    Lifetime Member Road's Avatar
    Feb 2015
    Default $0534
    I have summit-ed a support ticket also. I have a CM2200 that failed the patch file write and now is setting a $0534 invalid serial number and ecm is dead in the water. Trace files attached.20180525_161944_CMD_F.rar
    Nov 2005
    The controller should be recoverable by flashing a tune file without any security permissions. You should follow the steps outlined here. https://support.efilive.com/kb_artic...7233-PHJN-8346
    Cindy
    Sent from my iPad using Tapatalk
    Feb 2015
    Cindy
    I am flashing with out restrictions. Using my V2 direct flashing. Efi wont flash it because it wont detect a serial number assuming for licensing reasons.
    Mike unfortunately it was Sunday here when that support request came through, anyway the response in the trace file at the end is error $0340, download not accepted (meaning the anti-tuning security is still active).
    Because that flash has not been successful the ECM will be in boot mode, if you can please update to the latest software version that would be helpful as we have done some updates to bootmode recovery in that version.
    https://forum.efilive.com/showthread...ase-(May-2018)
    Feb 2015
    I was using latest beta software and should have posted in the beta thread. Back on Public release till further notice. Thank you
    Nov 2005
    Default $0534
    The beta was superseded by the public release, you will be upgrading not downgrading by using the May Public Release
  1. $0534 Unable to unlock previously autolocked LB7
    By vortecfcar in forum Duramax LB7
    Last Post: March 28th, 2014, 09:29 AM
  2. $0534 pleas help
    By astolte2 in forum Duramax LB7
    Last Post: July 3rd, 2013, 12:25 PM
