Results 1 to 10 of 10
Thread: Tune on 2018 6.7 ram
    Sep 2018
    Default Tune on 2018 6.7 ram
    I got EFI live from ppei. Then I try to install the tune it comes up with the code that the key is not on when the key is on. They even tried to tune in with my laptop and the tuner and it sad the same thing key not on. Any advice Would help me. Thanks
    Nov 2010
    Sounds like you need the SGM bypassed....
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    2018 needs the serial gateway module bypassed (it blocks OBD-II port messages), speak with PPEI about how to do that is probably your best bet.
    Edit: Funny Les I think we posted at exactly the same time.
    Sep 2018
    Ok thanks they told me my truck was messed up and I needed to take it to the dealer. That they have done many 18’s with no problems and the problem was on my end to figure it out . So thanks for helping me with your product .
    Nov 2010
    That is funny lol...
    On a different note, are the 18 files any different then previous 2350 files?
    Les Szmidt
    2007 5.9 Dodge Ram
    Quote Originally Posted by M.haskovec View Post
    If you Google 'Dodge SGW bypass' you'll see there is people selling harnesses that bypass this module and allow you direct access to the CAN bus. It is a common issue on all Dodge, Chrysler and Jeep vehicles from late 2017.
    Quote Originally Posted by 2007 5.9 View Post
    Layout wise no, but they are digitally signed using a different key so on a stock ECM you would not be able to flash in a 2018 file to an earlier ECM.
    Sep 2018
    Ok I got the cable and put it in. Now the flash goes to 99% and stops and gives 0540 code. Any ideas?
    Nov 2010
    Might have to flash a stock file from a 2015 in first....idk
    Les Szmidt
    2007 5.9 Dodge Ram
    That indicates the ECM still has the anti-tuning security active.
    You probably need to be talking with PPEI to make sure your Autocal (I'm assuming that is what you have) is running the newer releases that will disable that security for you.
    The software updates are posted here if you wanted to try yourself:
    https://forum.efilive.com/showthread...ase-(Sep-2018)
    Aug 2018
    Ok I
  1. 2018 CSP OSs?
    By Mitco39 in forum Cummins 6.7L
    Last Post: July 7th, 2018, 04:05 AM
  2. 2012 Ram stock tune
    By turk88 in forum Cummins 6.7L
    Last Post: April 16th, 2015, 03:03 PM
  3. 2012 Ram 3500 Stock tune 12351331AN Please?
    By crdth in forum Cummins 6.7L
    Last Post: April 15th, 2015, 01:57 PM
  4. 05 Dodge Ram
    By Zero1338 in forum Do you want to be a Beta Tester?
    Last Post: August 14th, 2012, 12:22 PM
  5. RAM Error
    By bobo in forum FlashScan V2 BB Logging
    Last Post: February 26th, 2008, 10:59 AM
