Results 1 to 10 of 10
Thread: Found something very helpful
    Default Found something very helpful
    So i was working on some transmission shifting tuning and after using EFI Live for 12 years i just noticed this helpful info at the bottom of the screen.
    Select one of the cells and at the bottom it shows engine rpm. Guessing it uses the Tire size and gear ratio to determine this?
    Yes, correct, it uses tire size, axle ratio and gear ratio to calculate the engine rpm's, I find it very handy in keeping the mph shift-points sane wrt rpm shift-points/limiters
    ( EFILive is excellent software )
    I cant believe i just noticed it.. But i have used a Dell Mini 9 Laptop with a 9" screen.
    Noticed it while using the work computer with a 24" screen
    The bigger screens help...
    Senior Member whackem04's Avatar
    Apr 2009
    Did they get this feature to work on the other trannys or was it only for his gen pcm?
    01 GMC Sierra 1500 SLE 5.3 cam swap
    Tuned by ME (COS 5 - running strong and smooth)
    Seems to me to work only for PCM's
    ( i.e. where engine rpm and trans gear ratios are in the same controller )
    Dual 22" screens vs Single 9" screen.
    I dont know how i made it for so long with that baby laptop.
    larger screens are quite cheap now.
    Especially when they are free at work...
    Well not free, but you know what i mean.
    lol... they are throwing out 24" screens because they are replacing them with 28" screens.
  1. Idle Tuning - Helpful Info Inside
    By SSpdDmon in forum Tutorials
    Last Post: September 5th, 2017, 09:54 AM
  2. Replies: 42
    Last Post: June 15th, 2010, 03:47 AM
  3. WB not found
    By driver456 in forum FlashScan V2
    Last Post: May 30th, 2010, 03:59 PM
  4. New here...I think i have a helpful write up for an OS swap...
    By Stangkiller in forum Custom Operating Systems
    Last Post: August 18th, 2006, 06:10 PM
