Results 1 to 2 of 2
Thread: Cal_adjust error in tune tool
    Default Cal_adjust error in tune tool
    First time i go to adjust my tune on my work computer i got this error.
    Did some reading and found out the file had some issues or something.
    Im working with a LS1B 512K PCM if that helps anyone.
    I got on my laptop and found the file under this.
    C:\Program Files (x86)\EFILive\V7.5\Configuration
    Copied the laptop file to the PC file and it worked.
    Another thing i found out is giving that EFI Live folder all privilages and run EFI Live Tune Tool as Administrator and it works perfect now.
    File is attached just incase some one is have this problem. Can copy it over if your working with a LS1B PCM.
    Quote Originally Posted by nonnieselman View Post
    Yes, correct...
    you can can do any of these:
    a. make yourself the owner of the folder, and give yourself all privileges on that folder.
    b. run the tunetool as Administrator (who typically has all privileges).
    c. what you said (if b. does not work).
  1. CME ecm error 400000 when using tune tool
    By modpcm in forum Cummins 6.7L
    Last Post: October 12th, 2015, 05:20 PM
  2. Replies: 22
    Last Post: June 20th, 2013, 03:45 AM
  3. Replies: 4
    Last Post: January 6th, 2008, 11:47 AM
  4. Fit to Scan Tool/Tune Tool
    By limited cv8r in forum General
    Last Post: March 3rd, 2007, 06:10 AM
