92 s10 extended cab
408 iron gen 3 Ls N/A
6 speed
Mammo spec'd 241/246hydr/roller 113+1
Mamo 235 heads
Johnson short travel lifters
mamo ported MSD Intake
Nick Williams 102
1 7/8 longtubes
Moroso 3 vane vac pump
FAST 36lb inj
11.7:1 comp
ok guys ive attached a tune im using with a log i did. It started as an 01 f body 6 speed tune. I adjusted the injector stuff, changed some idle airflow tables {i followed the rafig tutorial}, i didnt actually perform the rafig yet tho...
truck fires right up cold, will idle somewhat rough until about 140*ish then idle slows down and if i dont give her gas she dies. doesnt sound like shes running right tho. Warm restart i have to give her gas or she wont fire. Could use a bunch of help with this. I cant break the engine in yet cause i cant get her ti idle correctly. She doesnt run right on the stock tune. I have an LM2 wb . If someone could take a look at the file and give me some feeback i would greatly appreciate it. Also im trying to get a handle on setting up the scanner.
