Page 2 of 9 FirstFirst 1234 ... LastLast
Results 11 to 20 of 84
Thread: please help...
  1. #11
    Quote Originally Posted by Jayyk31 View Post
    No jocar im talking about crankcase vac. I have a 3 vane Moroso vac pump. Im using a gm 2 bar map sensor so i can monitor the crankcase vac thru the pcm and on my dash guage. I have it wired like this.
    Map connector B - PCM red 64 & dash guage
    Map connector c - PCM blue 47
    Map connector A - PCM blue23
    (This wiring is for '01 f body 2088 FTP sensor for vac pump)
    Im gonna double check my wiring as i might have gotten mixed up over the last year as ive changed from p59 pcm to the 0411.
    ***edit*** wiring is correct as per gm wiring diagram for 00-02 f body FTP sensor...
    Ah, I see, I was not aware you were pumping crankcase vac...
    good job on innovating with parts to monitor it
  2. #12
    Jan 2017
    My brand new Moroso 3 vane vac pump took a dump. Had vane material all thru the hoses and pump. Now i know why the guage was not moving from .82 in/hg... lol! I have to figure out why the pump failed but in the meantime i ordered a rebuild kit. Mon i drop the truck off to get full exhaust done finally and then i can resume my tuning. Doesnt make sense to mess around .
  3. #13
    That's too bad it failed... I'm curious as to what caused it.
  4. #14
    Jan 2017
    Yeah Joecar same here! Im thinking that b4 i plumbed the pump in i had the plastic intake and exhaust plugs in to keep dirt out. But i noticed they pertruded into the pump. I remember cranking the engine over to check oil pressure in the past. So im thinking when i did that the vanes might have made contact with the plugs and damaged them. I cant think of how else it could have happened? I have a rebuild kit on the way so it should be back up in a day or so and when i get the truck back from exhaust shop ill be back getting her dialed in!!!
    Ill take some pics of inside the pump when i break it down.
  5. #15
    Jan 2017
    Joecar i keep getting a p0463 code. In my pics i posted i have them set to no report and mil off. I left the tank vac pressure codes as non emissions in hopes i can record the data from that but the fuel level signal i keep getting a code... Any idea how i can turn that off?
ID:	22148   Click image for larger version.
ID:	22149   Click image for larger version.
  6. #16
    Jan 2017
    Doing the Rafig as, per the tutorial, do i set up a Histo for each temp threshold and adjust each temp in b4307?
    Also still not sure about p0463 code??
  7. #17
    For P0463, try setting it to MIL on (and Not-Reported).
  8. #18
    Jan 2017
    Will do, thank you!
  9. #19
    Jan 2017
    Joecar ive been trying to setup this CALC pid for the better part of the day!lol! Can u take a look and see if I have it correct? i dont find it in the scanner? Im setting up for CALC VE. Thanks
  10. #20
    ok, I'll look...
