Page 3 of 9 FirstFirst 12345 ... LastLast
Results 21 to 30 of 84
Thread: please help...
  1. #21
    Under CLC-00-003, there should be no blank line before VE (i.e. no blank line between the % line and the VE line).
    Also, at end of file, there should be at least 2 blank lines (i.e. hit ENTER twice).
  2. #22
    Jan 2017
    Thanks i will correct those things! Much appreciated!
  3. #23
    Jan 2017
    Im editing this txt doc in V8 Explorer. Should i do it in 7.5? Cause i applied the changes and still nothing? Ive looked fo the txt doc in 7.5 and cant find it.
  4. #24
    Edit the doc using Windows Notepad (or Notepad++ if you know how to get it).
    Rename the doc to calc_pids.txt and move it to the folder C:\User\<you>\Documents\EFILive\V7.5\User Configuration
    this doc defines calc pids for the V7 scantool.
  5. #25
    Jan 2017
    Joecar thanks a TON bro! I downloaded Notepad++ and followed exactly what u said to do and boom the 3 pid's were there in 7.5 scanner! Thanks for helping me and answering all my questions Joecar!!!
  6. #26
    No worries
  7. #27
    Jan 2017
    For some reason now i get this error message now. Im doing "autoVE" and i made this filter and had no issues a few different times. I make another, different, filter and now for both i get this message. I didnt unselect any pid's or anything. Weird???
  8. #28
    Post the file Filters.txt from the User Configuration folder.
    Post your log file.
    Are you logging the pids that the filter references...?
  9. #29
    Jan 2017
    Here's the Filters and my last log... I set ip up days ago and logged 3 previous sessions and the filter was good. As far as i can tell the correct pid's are check marked. I set it up exactly like the tutorial as far as I can tell. Yesterday I went in to set up a 2nd
    seperate filter to filter out all 60% throttle and up and that's when it started... I'm sure i messed something up. The message i get doesn't tell me a pid to select. Thanks Joecar
  10. #30
    Jan 2017
    I got it. Not sure what happened? I ereased the new filter i made and included it into the original filter and its good now.
