First time i go to adjust my tune on my work computer i got this error.
Did some reading and found out the file had some issues or something.
Im working with a LS1B 512K PCM if that helps anyone.
I got on my laptop and found the file under this.
C:\Program Files (x86)\EFILive\V7.5\Configuration
Copied the laptop file to the PC file and it worked.
Another thing i found out is giving that EFI Live folder all privilages and run EFI Live Tune Tool as Administrator and it works perfect now.
File is attached just incase some one is have this problem. Can copy it over if your working with a LS1B PCM.
