Originally Posted by
redhardsupra
2. yes it will, easily, i got logs to prove it. go 2barSD and AutoVE slowly, deeper and deeper into boost areas.
3. use the spreadsheet, works great
5. do NOT tweak IFR for any other purpose but adjusting for new injectors/fuel pressure/fuel pressure regulator
watch what rpm boost comes on, and adjust your PE triggers accordingly. remember that in turbos torque/compression hits early(before 3000rpm), so the NA config is very dangerous for it, as in NA configs, peak torque happens past 4400rpm. log gently, adjust accordingly.
