Results 1 to 3 of 3
Thread: Making Lemonade: It is possible to use LBZ tune on LMM ECM?
    Jun 2018
    Default Making Lemonade: It is possible to use LBZ tune on LMM ECM?
    So long story short my LBZ was totaled by a drunk driver. So I am trying to make lemonade from the lemons of this situation.
    I've since decided to swap the drivetrain into a newer gen platform and need the LMM ECM to be able to communicate with the newer gen controllers.
    Is there an easy way to transfer the LBZ tune from the LBZ PCM to an LMM one?
    Or can I flash the LBZ PCM to an LMM PCM?
    I admittedly haven't checked to the PCM's yet to even see if they are the same as I only have the LBZ one.
    Thanks gents
    Not possible, ECM hardware is different internally.
    Jun 2018
    Thank you sir!
  1. Converting an LMM tune to LBZ tune
    By wdw012 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 6th, 2014, 11:13 AM
  2. LBZ ECM & LMM EGT sensors
    By Cougar281 in forum Diesel
    Last Post: June 22nd, 2014, 12:44 PM
  3. LBZ/LMM Lope tune
    By LBZoom in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 12th, 2011, 01:55 PM
  4. Need LBZ ecm, willing to give immacculate LMM ecm as exchange
    By badassmax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 9th, 2011, 03:20 AM
  5. LMM ECM for '06 LBZ?
    Last Post: January 7th, 2011, 09:03 AM
