Results 1 to 7 of 7
Thread: COS3 4L80E segment swap
    Jan 2018
    Default COS3 4L80E segment swap
    I'm currently running a 4.8 with a COS3. If i want to install a 4L80E is this the correct way to do the segment swap?
    1.Use file from a 6.0/4L80E that has the same O/S as my original stock file.
    2.Upgrade that 6.0 file to the COS3 so it has the same matching O/S as my current tune file.
    3.Segment swap the Trans into my current tune
    I believe you should do the trans segment swap first, and then do the COS upgrade...
    but, let me check (it's been a while since I did both, so I have forgotten the details).
    Jan 2018
    Thank you for checking. I was hoping to do it the way I suggested because then I can keep my current tune settings in my COS3 file. If I have to do the segment swap before the OS upgrade i'll have to re-input all the settings again.
    I've forgotten more than you
    The right way to do this would be like this:
    1 - Swap in to the Stock OS the Trans and Trans Diag segments from the 4L80E file (needs to be the same OS).
    2 - Do the COS3 update based on that file you've just created.
    Jan 2018
    Thank you, that is how I'll do it.
    Ross, thanks.
    lol on forgetting stuff
    Create a script of your current COS3 file with the original "base" COS3 you started with (potentially long ago). Remove the Trans part as you'll have to re-do that anyway with the 80E. Once you have the new base+80E file, upgrade to COS3, then run the script to change all the engine tables/parameters to match your current file. Tune the trans.
  1. 04140003 OS and 4L80E ....Can it be done with segment swap ?
    By RetroAus in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 26th, 2023, 01:11 PM
  2. Need blackbox 4L80E tune for my 4L80E segment swap
    By Supercharged111 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 10th, 2013, 10:57 AM
  3. did segment swap to 4l80e have a question
    By Cool28 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 3rd, 2011, 11:42 AM
  4. 4l80e segment swap!!!
    By hyderm87 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 14th, 2009, 03:28 PM
  5. 4l80e segment swap!!!
    By hyderm87 in forum Custom Operating Systems
    Last Post: May 12th, 2009, 03:29 AM
