Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Increasing RPM & Speed with O Throttle Pedal Input
    May 2009
    A 6.2 or 454LSX would make even more sense
    Attachment 22263
    Here's a 69 Chevelle I did
    May 2009
    I don't think it should matter but there was an issue with the MAF wiring. Because of the way the ECU was installed behind the dash and impossible to get to without removing the entire dash I have it running SD.
    Could this have anything to do with it. I have run LS's in SD a ton of times before.
  1. Replies: 16
    Last Post: February 28th, 2018, 05:53 AM
  2. 2016 LML and Increasing speed limiter = no exhaust brake ?
    By staytuned in forum Duramax 2011+ LML / LGH
    Last Post: June 27th, 2017, 12:25 PM
  3. E78 throttle fluctuation with constant pedal position at constant speed
    By motoxxxman in forum E78, E83, E84 PFI ECM's
    Last Post: July 27th, 2016, 08:45 AM
  4. E78 throttle fluctuation with constant pedal position at constant speed
    By motoxxxman in forum E39, E80, E82 & E92 SIDI ECM's
  5. E37 & E67 OS compatability vs Throttle Pedal Sensors
    By Yellow05C6 in forum E37, E38 & E67 PFI ECM's
    Last Post: January 20th, 2015, 05:55 AM
