Page 8 of 19 FirstFirst ... 67891018 ... LastLast
Results 71 to 80 of 183
Thread: Start over,
  1. #71
    Dec 2014
    Get your fuel 100% before you worry about timing.
  2. #72
    Lifetime Member Tinbender59's Avatar
    Jun 2010
    R & R'ed #4 & #7 coils; checked both wires, under 1200 ohm's. Now #7 threw over 3500 misfires in 6 miles???? Could it be injectors?? I'll pull plugs as soon as i can, get a look at the color.
    Conectors aside will ford 5.0 injectors fit the LS1 motors??
    I have a set of 30# type 3's
  3. #73
    Dec 2014
    How long did the engine sit? We've gotten to the point we clean and flow test all injectors for conversions now.
  4. #74
    Jun 2010
    It was setting for 4+ years. I was thinking that. I guess injectors are on the agenda now unless i can find a place to get them cleaned
  5. #75
    Jun 2010
    Found a local shop that will clean and check the injectors for $14 an injector
  6. #76
    Quote Originally Posted by Tinbender59 View Post
    See if they will measure average flow of each, to see how closely matched they are (and so you can put the highest flowing injector in #7 and #8).
  7. #77
    Jun 2010
    Ok. Have my injectors back, here is a copy of test data, numbers do not match motor cylinders
  8. #78
    Jun 2010
    well it has been a battle but I finally have gotten the missfire counts down to "0". injectors cleaned, intake R & R'd, all good now.
    had to do a complete program load to get the DTC stuff
    now lets get down to business, where do I start??? lol
    here is the tune that is currently loaded tun, and a misfire scan
    my tune.ctz
    08052018.efi
  9. #79
    Jun 2010
    I have an appointment tomorrow at 11:00am to get certified for highway use, I hope to be able to get in a little data logging for tuning done 45 min drive one way. rechecking the tune and setting perimeters for SD tuning tonight.
  10. #80
    Let me know how it goes.
    Which State...?
  1. Start/Post start issue!
    By IJ. in forum Gen IV V8 Specific
    Last Post: September 3rd, 2013, 02:55 PM
  2. Cold start perfect, Warm start flares high
    By samh_08 in forum Gen III V8 Specific
    Last Post: May 12th, 2009, 09:36 PM
  3. Cold start great but warm start sucks."Idle
    Last Post: October 26th, 2008, 12:22 AM
  4. The First Start-up!!!!
    By RacerChris in forum Gen III V8 Specific
    Last Post: May 1st, 2007, 01:00 PM
  5. No start.
    By curtbriggs in forum General (Petrol, Gas, Ethanol)
    Last Post: April 19th, 2005, 12:04 PM
